Habe scheinbar nen Trojaner "Rundlg32.dll"
  • Wie bekomme ich den von der Platte !?
    Hier mal die Logfile von HijackThis!
    Logfile of HijackThis v1.98.2
    Scan saved at 11:55:16, on 25.09.2004
    Platform: Windows XP (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 (6.00.2600.0000)
    Running processes:
    C:WINDOWSSystem32smss.exe
    C:WINDOWSsystem32winlogon.exe
    C:WINDOWSsystem32services.exe
    C:WINDOWSsystem32lsass.exe
    C:WINDOWSsystem32svchost.exe
    C:WINDOWSSystem32svchost.exe
    C:WINDOWSsystem32logonui.exe
    C:ProgrammeGemeinsame DateienSymantec SharedccSetMgr.exe
    C:ProgrammeGemeinsame DateienSymantec SharedccEvtMgr.exe
    C:WINDOWSExplorer.EXE
    C:WINDOWSsystem32spoolsv.exe
    D:ProgrammeGoOnline V2GoOnline.exe
    C:ProgrammeGemeinsame DateienSymantec SharedccApp.exe
    C:ProgrammeJavaj2re1.4.2_03binjusched.exe
    C:ProgrammeNorton AntiVirusnavapsvc.exe
    C:ProgrammeNorton AntiVirusAdvToolsNPROTECT.EXE
    C:WINDOWSSystem32nvsvc32.exe
    C:ProgrammeGemeinsame DateienSymantec SharedCCPD-LCsymlcsvc.exe
    C:ProgrammeNorton AntiVirusSAVScan.exe
    C:ProgrammeInternet ExplorerIEXPLORE.EXE
    C:Dokumente und EinstellungenThomasDesktopHijackThis.exe
    R0 - HKCUSoftwareMicrosoftInternet ExplorerMain,Start Page = http://www.google.de/
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - D:ProgrammeAcrobat 6.0ReaderActiveXAcroIEHelper.dll
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:PROGRA~1SPYBOT~1SDHelper.dll
    O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:ProgrammeNorton AntiVirusNavShExt.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:WINDOWSSystem32msdxm.ocx
    O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:ProgrammeNorton AntiVirusNavShExt.dll
    O4 - HKLM..Run: [TCASUTIEXE] TCAUDIAG.exe -off
    O4 - HKLM..Run: [GoOnline] D:ProgrammeGoOnline V2GoOnline.exe
    O4 - HKLM..Run: [ccApp] "C:ProgrammeGemeinsame DateienSymantec SharedccApp.exe"
    O4 - HKLM..Run: [Advanced Tools Check] C:PROGRA~1NORTON~1AdvToolsADVCHK.EXE
    O4 - HKLM..Run: [SSC_UserPrompt] C:ProgrammeGemeinsame DateienSymantec SharedSecurity CenterUsrPrmpt.exe
    O4 - HKLM..Run: [NvCplDaemon] RUNDLL32.EXE C:WINDOWSSystem32NvCpl.dll,NvStartup
    O4 - HKLM..Run: [QuickTime Task] "C:ProgrammeQuickTimeqttask.exe" -atboottime
    O4 - HKLM..Run: [SunJavaUpdateSched] C:ProgrammeJavaj2re1.4.2_03binjusched.exe
    O4 - HKLM..Run: [nwiz] nwiz.exe /install
    O9 - Extra button: Trace - {04849C74-016E-4a43-8AA5-1F01DE57F4A1} - C:ProgrammeVisualRoutevrie.dll
    O9 - Extra 'Tools' menuitem: VisualRoute Trace - {04849C74-016E-4a43-8AA5-1F01DE57F4A1} - C:ProgrammeVisualRoutevrie.dll
    O9 - Extra button: (no name) - {10954C80-4F0F-11d3-B17C-00C0DFE39736} - (no file)
    O9 - Extra button: ICQ Pro - {6224f700-cba3-4071-b251-47cb894244cd} - D:ProgrammeICQICQ.exe
    O9 - Extra 'Tools' menuitem: ICQ - {6224f700-cba3-4071-b251-47cb894244cd} - D:ProgrammeICQICQ.exe
    O9 - Extra button: Recherche-Assistent - {9455301C-CF6B-11D3-A266-00C04F689C50} - C:ProgrammeGemeinsame DateienMicrosoft SharedEncarta ResearcherEROPROJ.DLL
    O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedCo…bin/AvSniff.cab
    O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedCo…n/bin/cabsa.cab
    [Editiert am 25/9/2004 von poncho]
  • Re: Habe scheinbar nen Trojaner "Rundlg32.dll"
    ich schätze mal den hat dir norton schon gelöscht, denn im Log ist davon nix mehr zu sehen....
    am besten machst du einen kompletten virenscan OHNE dass du sonst irgendwas am PC machst. NUR norton soll laufen.
    berichte dann mal bitte, was das Ergebnis ist.
    LG
    Anni
    Ich habe auch schon selber mal einpaar Zeilen in der Logfile gelöscht, die "richfind" enthielten,
    bei den restlichen war ich mir nicht sicher, deshalb wollte ich mal die Experten zu Rate ziehen [Blockierte Grafik: https://www.winpower.de/images/smilies/emojione/1f609.png] .
    Norton findet etwa 26 detected files, alle heissen gleich :
    Threat Name : Spyware.Iwantsearch
    Action Taken : Delete failed
    Item Type : File
    Source: rundlg32.dll
    Description: The compressed file rundlg32.dll within C:\windows\downloaded program files\conflict.3\rundlg32.exe is a spyware threat
    Leider existiert dieser Pfad nicht....
    Habe das empfohlene tool benutzt, die angebliche toolbar wurde auch deinstalliert, aber norton findet immer noch die besagten detected files.
    Möchte nochmal dazusagen, das ich mit dem IE momentan auch keine Probs habe, alles läuft
    normal. Alleine die files machen mir Sorgen.
    ein Proggi kann ich dir noch empfehlen: und zwar Escan hier in Antwort 6 sind Download und einstellungshinweise. Escan bitte im abgesicherten Modus durchlaufen lassen!
    berichte danach bitte, was noch so los ist.
    Habe das Proggi durchlaufen lassen (im abgesicherten Modus), er fand einpaar files, die er aber deleted bzw. renamed hat. Aber wenn ich norton starte habe ich immernoch das alte Problem...
    versuch mal Norton zu deinstallieren, und wieder installieren. Bevor du ihn wieder installierst, mit Regsupreme bitte alle reste entfernen aus der registry. Vielleicht "hängt" er irgendwo. Wenn auch das nicht hilft, würde ich sagen, am besten die kiste neu aufsetzen. Format c:
    LG
    Anni
