Minidump Auswertung Hilfe.
  • Hallo
    Habe mein Rechner neu zusammengebaut und mal das Windows 7 getestet.
    Sporadisch kommen immer wiedermal irgendwelche Bluescreens.
    Habt die mal anhand der Minidump files Analysiert, bzw habe ich das vor.
    Hab sie mit Wndbg ausgelesen.
    Microsoft ® Windows Debugger Version 6.11.0001.404 AMD64
    Copyright © Microsoft Corporation. All rights reserved.
    Loading Dump File [C:\Windows\Minidump\082809-53336-01.dmp]
    Mini Kernel Dump File: Only registers and stack trace are available
    Symbol search path is: C:\symbols
    Executable search path is:
    Windows 7 Kernel Version 7100 MP (4 procs) Free x64
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 7100.0.amd64fre.winmain_win7rc.090421-1700
    Machine Name:
    Kernel base = 0xfffff800`02e17000 PsLoadedModuleList = 0xfffff800`03050e90
    Debug session time: Fri Aug 28 05:32:57.381 2009 (GMT+2)
    System Uptime: 0 days 0:00:36.786
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    Use !analyze -v to get detailed debugging information.
    BugCheck 3B, {c0000005, fffff80002eaaeb8, fffff880039e0f30, 0}
    Probably caused by : memory_corruption ( nt!MiReplenishPageSlist+c8 )
    Followup: MachineOwner
    1: kd> !analyze -v
    SYSTEM_SERVICE_EXCEPTION (3b)
    An exception happened while executing a system service routine.
    Arguments:
    Arg1: 00000000c0000005, Exception code that caused the bugcheck
    Arg2: fffff80002eaaeb8, Address of the exception record for the exception that caused the bugcheck
    Arg3: fffff880039e0f30, Address of the context record for the exception that caused the bugcheck
    Arg4: 0000000000000000, zero.
    Debugging Details:
    EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
    FAULTING_IP:
    fffff800`02eaaeb8 f00fba6b1000 lock bts dword ptr [rbx+10h],0
    CONTEXT: fffff880039e0f30 -- (.cxr 0xfffff880039e0f30)
    rax=00008000002118b6 rbx=0017fa800634a220 rcx=0000000000000000
    rdx=0000000000000050 rsi=0000000000000003 rdi=000000000000000d
    rip=fffff80002eaaeb8 rsp=fffff880039e1910 rbp=fffffa800634ae20
    r8=fffff800030bd400 r9=fffffa8006900000 r10=fffffa8006900890
    r11=fffff8800000003f r12=2aaaaaaaaaaaaaab r13=fffffa8006900870
    r14=fdffffffffffffff r15=0000058000000000
    iopl=0 nv up ei pl nz na pe nc
    cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00210202
    nt!MiReplenishPageSlist+0xc8:
    fffff800`02eaaeb8 f00fba6b1000 lock bts dword ptr [rbx+10h],0 ds:002b:0017fa80`0634a230=????????
    Resetting default scope
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
    BUGCHECK_STR: 0x3B
    PROCESS_NAME: csrss.exe
    CURRENT_IRQL: 2
    LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff80002eaaeb8
    STACK_TEXT:
    fffff880`039e1910 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiReplenishPageSlist+0xc8
    FOLLOWUP_IP:
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: nt!MiReplenishPageSlist+c8
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: nt
    DEBUG_FLR_IMAGE_TIMESTAMP: 49ee9439
    STACK_COMMAND: .cxr 0xfffff880039e0f30 ; kb
    IMAGE_NAME: memory_corruption
    FAILURE_BUCKET_ID: X64_0x3B_nt!MiReplenishPageSlist+c8
    Kann jemand damit was anfangen??
    Hab da auch noch ein paar mehr davon
    Lg Nosomebody0
  • Hi
    die (wahrscheinliche( Fehlerursache steht ja doch hier =)
    Bau mal nur 1 RAM-Riegel rein und schau mal wie es sich danach verhällt.
  • Am ram kanns eigentlich nicht liegen hab ein Memtest gemacht nach 9 stunden hab ich abgebrochen da war nix.
    Kennt sich jemand mit Bios Einstellung aus vom P5Q-e mit 8GB Corsair Dominator 1066 und einem Q9550.
    Lg Nosomebody
  • So hab mir das mal genauer angesehen, vorhin wars ja nur so überflogen
    Die 2 Bezeichner "MODULE_NAME" und "IMAGE_NAME" sagen welche Programm welchen Fehler verursacht hat. Als modul steht da "nt", also Windows an sich. Hast du noch die alte Beta oder den RC?
